Add options to Control Tag node to set a smaller range of Mouse Proximity for most accurated management.
Based on the real shape volume of the control will be the best option in case of mesh shapes. Anyway could be good adjust the drop off distance or proximity distance from the mouse cursor to the center/bounding box of the shape, for each control tag node. Now is not possible play with that.
I attached a link to an example video showing the long distance that is activated by defaul. If I add more controls for all the character, I need adjust a smaller distance to activate the visibility, in a small number off controls around the mouse.
I think that can be really usefull add more attributes and Input-Output connections to this node. Like output to connect to visibility attributes.
Regards!
