AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Add A/B Options for MatchUVs Command
When selecting two UV shells and running "Match UVs"  both shells are modified.  This is less than ideal when one shell should be treated as the target.  The tool would be more useful if it had options for : first matches second, second matches first, or average (the current behavior).  In the UV Toolkit these options could be represented with two buttons labeled "A" and "B" (similar to all the U/V tool filters).
