Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
xGen throws the following error when creating density maps: Error while trying to do ptexBake
0 REPLIES 0
Message 1 of 1
calicocatG4AGK
38 Views, 0 Replies
// Error: line 1: XGen: Failed to find hair_desc/paintmaps/test4mask/Hair1.ptx
// Error: line 1: XGen: Searched path includes:
// C:/Users/sean/Documents/maya/projects/default/xgen/collections/browB_col/hair_desc/paintmaps/test4mask/Hair1.ptx (Part of path doesn't exist)
// C:/Users/sean/Documents/xgen/hair_desc/paintmaps/test4mask/Hair1.ptx (Part of path doesn't exist)
// C:/Program Files/Autodesk/Maya2023/plug-ins/xgen/presets/hair_desc/paintmaps/test4mask/Hair1.ptx (Part of path doesn't exist)
The files are never created and if I attempt to edit the map and/or save it Maya crashes.   It does not matter if I create a new project or open an old project.  Grooming hair and creating guides is no issue, only when we go to create a map.
I've tried giving Maya admin privileges but it still cannot create these files.
I've tried changing project locations as well but the same issue occurs.
I see a similar issue: Solved: Maya fails to do ptexBake - Autodesk Community - Maya
but I don't see a listing of the project setting which causes the issue
Tags (1)
0 REPLIES 0
