XGen - Styling question
Message 1 of 12
I'm new in XGen, but I like it and I intend to learn it. I'd like to make a french wig. I have some styling problem, that the guides not exactly follow the hair. Some example:
Replies (11)
Message 2 of 12
Message 3 of 12
So if we have different long of hair, then worth use new description? For ponytail? Need cut the ponytail or better use 2 description (top and lower side)?
Message 4 of 12
Message 5 of 12
This is also strange: (only primitives in the view OFF, no modifier)
When delete the second guide, hair spread out, but why?
Message 6 of 12
Some guide follow the hairs, but some why not?
Message 7 of 12
How can I control the the thickness? Thickness is random?
Message 8 of 12
You can see there are many overlapped hairs, possible to remove the overlapping?
Message 9 of 12
Any idea?
Message 10 of 12
Looks like if "clumping - guide - on" region map (big resolution) not work correctly
Message 11 of 12
The hair with region control looks like too flat, how possible make big thick waves?
Message 12 of 12
b00nb00n
Have you find any solution yet? I am facing the same problem too 😞
