Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Xgen problem when i import scene
9 REPLIES 9
Message 1 of 10
adrienp92310
373 Views, 9 Replies
Hi everyone
(this is my first post btw)
I meet a problem about xgen
when I import a scene in a scene with xgen my is okay but when I close this scene and I re open, my xgen disappear
Thank you in advance for help.
Tags (2)
9 REPLIES 9
Message 2 of 10
sean.heasley
in reply to: adrienp92310
Hi @adrienp92310
What are you trying to import into the scene?
Also, what version of Maya are you working with and is it up to date?
Message 3 of 10
adrienp92310
in reply to: sean.heasley
hi
I try to import a simple object and a decor (very basic model), and my fur disappear or bug when i re open the scene
I work with maya 2019 and my maya is not update
Message 4 of 10
sean.heasley
Hi @adrienp92310
Are you putting the fur on the model you imported or is the fur already on another model when it disappears?
Have you tried hitting the refresh eyeball icon on your Xgen groom?
Finally, try unloading and reloading your Xgen plugins and see if that changes anything.
Message 5 of 10
adrienp92310
 the fur is already here and  i try to import a another scene
of course i try to refresh with the eyeballs ^^ and i try the last solution and nothing changes ...
I dont know why i cant import a objet in scene with my character without bug
i try to change import setting maybe but nothing change
ty for help BTW
Message 6 of 10
sean.heasley
Hi @adrienp92310
If you create a new scene with a basic sphere and apply some fur to it can you try importing and see if anything changes?
I'm trying to reproduce this issue with 2019 but its not happening on my end.
Message 7 of 10
adrienp92310
hi
ty for ur help
i just want to die ... i try ur last solution in my personnal computer and my fur bug again AND i try an a another computer and i dont have the problem... so i need too restart everything ?
where is the problem ?
I already tried to export my work in a another computer but the problem follow my project
Message 8 of 10
adrienp92310
hi
when i restart the fur in directly in my scene ( no import ) the fur bug Capture.PNGCapture1.PNG
Message 9 of 10
sean.heasley
Hi @adrienp92310
So the fur problem doesn't happen at all on the other machine?
Are there any major differences between the machines or Maya versions?
You could try deleting your settings/preferences and/or you may want to perform a clean uninstall/reinstall of Maya to completely set your Maya to default to make sure that isn't the issue.
Message 10 of 10
sean.heasley
Hi @adrienp92310
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
