Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Xgen interactive groom reference issues
15 REPLIES 15
Message 1 of 16
brurpo
2791 Views, 15 Replies
Hi there
I have a char that I am referencing in a bunch of scenes:
If I save my file with this char referenced in a pose other the the neutral, when I open it again this happens:
 It looks like as if the hair is being affected by some kind of gravity.
If it is saved in the default pose, everything works, including the batch render animation.
I have no idea whats going on.
Any ideas? Thanks a lot!
15 REPLIES 15
Message 2 of 16
sean.heasley
in reply to: brurpo
Hi @brurpo
Out of curiosity, if you delete the Xgen hair and reference and save the character in a different position does the same issue occur?
I'd like to narrow this down to an issue either with the hair or the rig itself not being referenced properly.
Please let me know if anything changes!
Message 3 of 16
brurpo
in reply to: sean.heasley
Hi there!
Thanks for the reply!
There is no issue with the char or the rig. We are already using it without the hair in our pipeline.
The problem is with xgen, if the scene is saved with the character in a pose other than the one in the reference the hair bugs and is all messed up when reopening the scene or doing a batch render.
This does not happen if I import the character instead of referencing it (but this is not an option for us, as we already have the char animated with lots of constrains and just need to replace it with the one with hair).
The solution that I am using right now is keying the char in the T pose, with every controller zeroed out, at frame 0, so its just like in the reference file and save the file there. (this give us motion blur problems so its not a perfect solution)
It seems like an odd bug with xgen, or I am doing something really stupid, I dont know.
P.S.: I am not using namespaces
Message 4 of 16
brurpo
@sean.heasley You can reproduce the error yourself, following these steps.
1- create a sphere
2- create an interactive groom
3- do some simple grooming
4- save the file
5- create a new file
6- reference the groom sphere file
7- rotate the sphere 45 degrees
8- save the file
9- reopen the file and the hair is messed up
ADITIONAL STEPS
10- Rotate the sphere back to 0 degrees
11- save the file
12- reopen the file and the hair is normal again
Message 5 of 16
sean.heasley
in reply to: brurpo
Hi @brurpo
Thanks a ton for the repro steps!
This does look like an issue with Xgen so I went ahead and logged this with our dev team so they can work on a fix!
Message 6 of 16
brurpo
Hi!
Thanks a lot.
If it's not too much trouble, please keep me posted if there is any news about it.
Message 7 of 16
sean.heasley
in reply to: brurpo
Hi @brurpo
Sure thing!
Message 8 of 16
jencruz93
Has there been any new updates on this?
Message 9 of 16
Any news on this? We have the same issue...This is 2018update5
Cheers...
Message 10 of 16
zenop
in reply to: brurpo
Same issue here.
Message 11 of 16
lucianVGFAA
in reply to: brurpo
same issue now in 2022
Message 12 of 16
jerry
in reply to: brurpo
Any news on this issue?
Message 13 of 16
brurpo
in reply to: jerry
Yeah, no, guess 5 years is not enough time to fix a critical issue.
That happens in multiple fronts, thats why we are phasing out autodesk for other solutions wherever we can
Message 14 of 16
jerry
in reply to: brurpo
Sorry to hear that.
I'll let you know if I have any luck down the line.
Message 15 of 16
isabel.song
same here...
Message 16 of 16
brurpo
in reply to: brurpo
I will start singing happy birthday every year this issue continues without a fix.
Almost 6 years, nice.
