Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Xgen holes between hairs
3 REPLIES 3
mattiabuccarelli
234 Views, 3 Replies
Hi everyone,
my first post here. Happy to be part of the family
I started using Xgen and I'm experiencing a weird issue to which I can't find a solution.
I have an hole in the hairs that i created.(attached image) I know that there is an interpolation between the hair guides, so i placed another guide where there is the gap but it doesn't solved the issue. Furthermore i mirrored those guides and this happens only on one side, the other one it works good.
I don't know what may cause those holes, someone has a clue?
3 REPLIES 3
For me this looks like the density map.
Are the uvs clean?
https://linktr.ee/cg_oglu
Hi @Christoph_Schaedl i have painted the density map in zbrush, and i applied it to the model as color texture first, to use it as guide, and than i loaded it as a density map.
The UV's should be good. Are they not?
The uvs are really small its possible that you need more resolution.
