Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
xGen - Deleted Material From Hypershade
4 REPLIES 4
1002 Views, 4 Replies
I just started learning how to use xGen to create fur, so I applied xGen "Groom" type to an object, everything was fine so far.
Then I accidentally deleted the xGen material in the Hypershade and a default material was applied to my xGen fur automatically, and now for obvious reasons it doesn't show up while rendering using Mental Ray.
So what I did was create another object, apply xGen Groom to it so another xGen material was gonna appear in the Hypershade, it worked, I applied that new xGen material to my fur and it still doesn't render, any idea on how to fix?
_________________________________________________________________
TL;DR
I deleted the main xGen Material from the Hypershade and now my object's fur doesn't show up in the render, how do I fix this?
4 REPLIES 4
bump.
How do I apply an xGen material to my xGen fur?
J450NP13
Select your fur then in the hypershader right click on the material you want it to have and mouse over assign shader to selected.
in reply to: J450NP13
Would you keep helping me out?
I found the trouble, I made a new scene and applied xGen to a new object, compared it with my other object on a different scene, and found out I don't have "xgmr:geoshader" on the scene I have trouble on (picture below of the thing I don't have), to make sure that was the problem I deleted it and I couldn't render the new object's fur, so basically how do I get the "xgmr:geoshader" back into my main scene file?
Solved
In case anyone had the same problem and need the "xgmr:geoshader" back you need to
- Open xGen editor
- Go to Preview / Output tab
- Search for "mental ray Settings" sub-tab
- Click on "Setup" button
That's it, it generates another geoshader
Technology Administrators
