Announcements
Workspace and Viewport problem
On top right, I was using the Maya Classic* Workspace option, but somehow I deleted the animation-time block which is supposed to be on the bottom, where you can set the fps and you can key and where the slide goes to the right if you start an animation and everything, you know. So that panel is just deleted and I don't know how to bring it back, so I've been using the Workspace: Animation but somehow my Viewport panel is covered by RenderView's window. I have the RenderView as the Viewport Panel. In the picture, you can see. Any idea, please?
Edit: I Fixed it: Windows ->  Workspace -> Reset 'Maya Classic' To Factory Default
(I have not found a way to delete post)
