Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
why is Maya filling scene files with unnecessary plugins
3 REPLIES 3
wreliford
770 Views, 3 Replies
When I open a scene file I created in 2020.2, I get all the unnecessary errors for plugins I don't even have on my system.
I can edit the .ma file and delete this lines but why does Maya bother with including these in the first place. What is the cause and how do I stop it.
Here is an example of the error and there are at least 45 of them all different:
# Error: file: C:/Users/wreli/AppData/Local/Temp/wreli.20200603.1746.ma line 24: RuntimeError: file <maya console> line 1: Plug-in, "realflow", was not found on MAYA_PLUG_IN_PATH. #
I don't and never had realflow on my system.
Here is what I edit out of the .ma file:
requires "AM_Velvet" "3.0";
requires "vrayformaya2008" "1.0";
requires "3delight_for_maya2011" "2";
requires "AM_Glossy_30" "3.0";
requires "NormalBump2D" "1.0";
requires "BPT_Bevel" "1.0";
requires "rpmaya" "2.0";
requires "CorrectiveShape70" "7.0";
requires "ByronsPolyTools" "1.0";
requires "skinShapeDeformer" "1.0";
requires "FumeFX" "FumeFX3.5-DEMO-2013_06_03";
requires "xfrog4.0" "1.0";
requires "moebiusPass" "4.0";
requires "bctrial16_maya2008" "Trial 1.6o";
requires "FurryBall_2009" "1.3.3.950";
requires "RenderMan_for_Maya" "3.0.1";
requires "HSVadjust2" "4.0";
requires "weightDriver" "1.8";
requires "TurtleForMaya2008" "4.1.0.3";
requires "JSNormalMapper_2008_64" "6.0";
requires "mtorsubdiv" "1.1";
requires "JSNormalMapper_2009_32" "2009";
requires "JSNormalMapper_2009_64" "2009";
requires "MayaMan_m4" "1.0.1";
requires "TurtleForMaya2009" "5.0.0.5";
requires "am_metaballs" "3.0";
requires "TurtleForMaya60" "0.352";
requires "md_RayDiffuse" "1.0";
requires "TurtleForMaya70" "2.1.0.0";
requires "TurtleForMaya80" "4.0.0.6";
requires "TurtleForMaya85" "4.1.0.4";
requires "bfcLookDev" "6.0";
requires "xfrog" "1.0";
requires "pdiMaya2x" "2.5";
requires "cartoonShader50" "5.0";
requires "correctShape2013x64" "0.0.7 build Friday 12/5/12 2:15 AM";
requires "elastikSolver" "0.990";
requires "finalRender" "1.0";
requires "libCausticMap" "2.0";
requires "libSkinA" "1.0";
requires "libSkinShader" "1.0";
requires "magicAssetNode.py" "Unknown";
requires "syflex" "3.52";
requires "maxwell" "2.5.12";
requires "ngSkinTools" "1.0beta.875";
requires "realflow" "2013.0.1";
Also, I get this error as well:
# Error: You are attempting to load a file that contains legacy render layers into a scene that uses render setup. This combination is unsupported and may result in unexpected behavior. #
What gives?
3 REPLIES 3
in reply to: wreliford
Hello
Pls Please have you found a solution to this problem? On the deadline, I have also encountered such an error problem, and then, when looking for a solution, I noticed your post, I hope to communicate with you, thank you!😀
hamsterHamster
If not really used in scene, safe to ignore.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
damaggio
in reply to: 493359766
These unused plugins come because at some point the user imported a scene that was using those plugins.
Just make a shelf button out of this script and remember to check the scene from time to time and specially when is completed so that the library is clean.
string $unknownNodes[] = `ls -type "unknown"`;
for($node in $unknownNodes) {
print( "Deleting " + $node + "\n" );
lockNode -lock 0 $node;
delete $node;
string $plugin;
string $unknownPlugins[] = `unknownPlugin -query -list`;
for ($plugin in $unknownPlugins)
unknownPlugin -remove $plugin;
