Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Why do OBJ meshes sometimes break when I import 2 OBJ meshes into one scene?
2 REPLIES 2
Samsam2019
738 Views, 2 Replies
So 2 OBJ files exported from Maya then put together in a scene cause one mesh to break apart as in every face has is its own object?
This doesn't really happen with FBX exports but I notice it does with OBJ's?
2 REPLIES 2
hamsterHamster
in reply to: Samsam2019
With objExport.mll v.6.5 @ M2019, I could not replicate your scenario; tried various export options/combos. Yes, I've dealt with those split meshes before, and my guess regarding such topology is, it could be related to Normals | Smoothing settings upon export, as this is a way of making edges hard - by splitting the geo where the hard edges supposed to be.
Overall, my experiment always produced meshes with geo my Maya doesn't handle well and crash. E.g. selecting a face offsets the pivot to an unpredictable location, then transforming the selected face actually transforms other unpredictable elements at best, if not crashing. I've also dealt with such kind of geo, the Mesh>Cleanup doesn't do a thing, and I could not find any other safe fix than rebuilding the geo from scratch, a complete bummer.
VERDICT: unless you have updated plugin version (see plugin's Info in Windows>Settings>PluginManager list), avoid OBJ format completely, stick to FBX if you absolutely have to use non-Maya format.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Tags (4)
Samsam2019
in reply to: hamsterHamster
Thank you, I think it is because of the smoothing meshes.
