Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Which version of libtiff library does maya2022 use on Linux?
8 REPLIES 8
Message 1 of 9
ttan0037
946 Views, 8 Replies
I am one of the Maya arch AUR package maintainers.  One of the library dependency of libmayaOpenImageIO.so.2.0.5 is libtiff.so.5.  However, when I execute the command "ldd libmayaOpenImageIO.so.2.0.5", it complaints "./libmayaOpenImageIO.so.2.0.5: /usr/lib/libtiff.so.5: no version information available (required by ./libmayaOpenImageIO.so.2.0.5)".  libtiff 4.3.0 was installed on my machine and it provides libtiff.so.5.  So, what's the problem?
Tianchen
Tags (2)
8 REPLIES 8
Message 2 of 9
Nicolaas.tanghe
in reply to: ttan0037
i got it running a while ago but had 2 reinstall becouse of dualboot.
now i also get the error.
./maya.bin: /usr/lib/libtiff.so.5: no version information available (required by /usr/autodesk/maya2022/bin/../lib/libmayaOpenImageIO.so.2.0)
Message 3 of 9
millermaneo
Seeking the same information. Where are the devs when you you need them lol
Message 4 of 9
Well only Redhat 8.2 ect. are supported.
So they don`t really have any responsibility to help us out.
I`m just happy it runs on Linux in the first place.
Message 5 of 9
did you get past the issues with segfault that was happening as well the lib tiff issue?
Message 6 of 9
Nicolaas.tanghe
I have Not yet transitioned to using redhat.
A person on the arch aur did post this and I`m pretty sure it will whould fix it on all distro`s.
I solved the libtiff.so.5 problem by compiling it by myself but I still have the segfault problem.
If you want to solve the libtiff issue before it got solved by Arch, you can just go download the last libtiff release on the official website, and compiling it with the symbol flag: ./configure --enable-ld-version-script make make install
Also by default it install it under /usr/local/lib*, so you have to create a link to /usr/lib/
" ~cuissedemouche https://aur.archlinux.org/packages/maya/
Message 7 of 9
ttan0037
I've created a bug report for libtiff package, please upvote to get it fixed ASAP, link: https://bugs.archlinux.org/task/71330?project=1&string=libtiff.  Currently, you will need to manually edit the PKGBUILD file with --enable-ld-version-script option to fix the issue.
Message 8 of 9
Nicolaas.tanghe
Can`t seem to register on that part of the forum i dont get a mail with conformation.
when i try to login with my normal aur i dont get anything.
Message 9 of 9
jesinroyD2A3A
Hello
Was anyone able to figure out what was causing the segfaults?
It works perfectly fine in windows but the same file just crashes the moment I open it on linux.
Any pointers would be really useful.
Thank you.
