Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
When rendering, it turns black after a certain frame.
7 REPLIES 7
Message 1 of 8
onurmx
228 Views, 7 Replies
When rendering, it turns black after a certain frame. no matter which frame I start from, after about 35 it turns black. there is nothing wrong with the stage. works in preview.s.png
7 REPLIES 7
Message 2 of 8
Christoph_Schaedl
in reply to: onurmx
What does the render log say?
https://linktr.ee/cg_oglu
Message 3 of 8
onurmx
in reply to: onurmx
I didn't wait until the end as there are thousands of frames. During rendering, the render log is as follows
runs smoothly. As I said, if I had started from the 2nd frame, the 37th frame would have been black. I'm using the maya student version, is it because of that? I wonder if the arnold trial version is from that?
Actually, it was making less frames before, but when I increased the value of render settings>arnold renderer> textures max cache size(MB), it went up to thirty.
Anyway, I've searched a lot on the internet but I can't find a solution.
Message 4 of 8
Christoph_Schaedl
in reply to: onurmx
We need a debug log.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-get-...
Message 5 of 8
onurmx
in reply to: onurmx
Thanks for your time cg_oglu. I found the file path, I'm sending it. I didn't want to wait for thousands of frames, so I turned it off when it started to turn black.
Message 6 of 8
onurmx
in reply to: onurmx
I deleted the old log file and rendered a new one, but I think it was interrupted
Message 7 of 8
Stephen.Blair
in reply to: onurmx
Can you increase the log verbosity to Info?
Render Settings > Diagnostics
Looks like there were no errors, but that's all we can tell at the moment...
// Stephen Blair
// Arnold Renderer Support
Message 8 of 8
onurmx
in reply to: onurmx
This is how i solved the problem:
I deleted maya 2023 and loaded maya 2022. later on. arnold I reduced it from 5.x.x.x to 4.x.x.x
Thank you very much to everyone involved
Thanks to Maya
Thanks to Arnold
I have finally completed my student project. Have a look below.
https://www.youtube.com/watch?v=5amZkvRT_Ko
