When I use Studio Library, 'Fatal Error. Attempting to save in ~' is always come out.
I'm using maya 2018 version . and I use Maya Script File (MEL) to install Studio Library.
I could install that. but I could not use that.
The warning,
' Fatal Error. Attempting to save in C:/Users/,,,/AppData/Local/Temp/,,,.20200817.2207.ma' come out.
I think I did everything I can do to solve this problem.
Could you guys help me?
alec.andersenLP8AU
Hi @Anonymous,
The error you're getting is actually Maya's traditional error when failing to save the current scene before close. This can stem from a wide variety of causes. If you're having an issue with the studio library plugin, i'd suggest following this guide to reinstall if you think Maya's installation may be the cause.
Perform a clean uninstall | Download & Install | Autodesk Knowledge Network
It's worth noting that sometimes plugins like this have their own limitations, it's always good to make sure you're using the version of Maya that they specifically recommend!
