Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
When did Maya restrict colorGain and colorOffset to a minimum of zero?
3 REPLIES 3
mcw0
295 Views, 3 Replies
I used to do simple math with these attributes.  Going to negative values.  But today, I tried and can't go below zero.  Why did Maya change this?  Please put it back the way it was.
3 REPLIES 3
damaggio
in reply to: mcw0
Just change color mode to RGB and enter your negative values.
mcw0
in reply to: damaggio
That does work.  But it's not as easy as it used to be.  Why did it change?  I used to be able to just set the value of the hsv value field to any value.  And in the channel box, I still can't go below "0".  Even when the mode is set to RGB.  You can only set the negative values in the color picker box.  Very inconvenient.
Maya does this a lot.  They lose the easy functionality of simple processes as they version up.  A real shame.
damaggio
in reply to: mcw0
You are preaching to the choir Manny.
