Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Weird cuts (white lines) when turn on UV texture borders
3 REPLIES 3
kharlamovav1
144 Views, 3 Replies
Hello, I need some help!
I started to learn UV mapping but cannot go further because I have some weird white lines on the mesh when I turn on the texture border. And with those lines, I can not do a clean cut. Tho, when I turn off the texture border they disappear. (you can see those lines below the nose and between the lips)Screenshot (185).png
I would really appreciate any ideas for help. Thank you in advance!
3 REPLIES 3
damaggio
in reply to: kharlamovav1
It just means that the Uvs are cut in that area.
kharlamovav1
in reply to: damaggio
Thank you for your response:)
yeah I though so but is there a possibility to remove these cuts to the way it was before? Cuz with them uv map is getting messed up.
damaggio
Just sew them back together.
