Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Wacom Middle Mouse Button is not working in Maya2023.
2 REPLIES 2
amaterasu-qbb
415 Views, 2 Replies
Hello. I used Maya2019 and moved to Maya2023. But in Maya2023, it does not work the same way as in Maya2019.
For some reason, it behaves the same as a right-click.
I have turned Windows Ink on and off and nothing makes it better.
I also switched Mode between pen and mouse, but that didn't help either. (I don't want to use mouse mode.)
Does anyone have a solution? If not, I will downgrade the version.
Translated with www.DeepL.com/Translator (free version)
Tags (2)
2 REPLIES 2
works perfectly fine here (with and without windows ink). maya 2023.2 and wacom driver 6.3.46-1.
Hello everyone!
I found out how to fix it and would like to share it with you.
  1. Uninstall the driver.
  2. Reinstall the driver.
  3. Setup from Wacom Tablet Properties.
Now it works fine. Thank you very much.
