Hi guys, I've been getting a very annoying issue and can't seem to find any info on it.
When I open up Maya, the viewport literally doesn't update. If I close all my tabs, such as outliner and attribute editor (so that my screen only has viewport open), then it works. If I, let's say, open up the outliner, the viewport becomes unresponsive. Oddly enough, I can see the info bar on the bottom left saying stuff like 'Rotation' when I rotate the camera, and if I then close the outliner again, I can see that my camera has indeed rotated. So it 'works' but I cannot see it unless I have closed all my tabs.
I have tried deleting preferences, it did not help. It MIGHT (cannot confirm this 100%) have something to do with the latest nVidia drivers, that's the only thing I can think of when it just started out of nowhere after using Maya for over a year.
Thanks in advance for anyone who might be able to help with this.
Hi @markoleppanenvfx and welcome to the community!
Like you guessed, this is most likely a GPU issue. What GPU are you using and is the driver version the same as our certified hardware list?
You can find our certified hardware list here!
If it is not the same, you'll want to uninstall your current GPU driver and install the certified version then launch Maya again.
Please let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
