Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
View Cube keeps randomly turning off (Maya 2020)
3 REPLIES 3
kennygecko1234
510 Views, 3 Replies
Hello, I am having an issue with Maya. I have figured out how to bring back View Cube by selecting Legacy Viewport.
However, the View Cube would randomly disappear after a few minutes, and I have to turn it back on.
Another problem: Sometimes the Viewcube disappears, even when the Option to turn it on is checked.
How do you fix this?
Also note: Sometimes, the ViewCube would appear, even if the option is set to OFF. (screencaps provided)
Tags (4)
3 REPLIES 3
vladtofan
in reply to: kennygecko1234
Same problem on 2022.3... still not fixed...
brentmc
in reply to: vladtofan
The multi-cut and connect tools are turning off the viewCube. To re-enable the viewCube you can either:
1) Ctrl+F and type "viewcube"
2) run this Mel command:
viewManip -visible on
Brent McPherson
Principle Engineer
vladtofan
in reply to: brentmc
Same problem on 2023... still not fixed...
