After Mapping the objects i selected all and used the "Layout" Tool, but everything is out of Scale!
The whole house is displayed samller then a piece of a Horn...
I also put on a Checker Lambert. and exported it as OBJ and tryed it on a new scene..
Solved by Christoph_Schaedl. Go to Solution.
When you open the Layout UVs Options dialog, what have you got Prescale set to?
you need to turn on shell prescaling...
Only Works if i export it again as a seperate new OBJ File .
Thank you it worked.
