When I try to use the layout tool on the student version of Maya 2018, it doesn't give me the switch option to Unfold3D and is not keeping the scale. I used the tool to layout the UV's for two objects that are exactly the same size and it made one object extremely small and one extremely large.
How do I reset the tool so that it is the current version of the Layout tool?
Solved by sean.heasley. Go to Solution.
Hi @Anonymous and welcome to the community!
Do you have the Unfold 3d plugin enabled?
You can check this by going to Windows->Settings/Prefs->Plugin Manager and then scroll down until you see Unfold3d.mll.
If that doesn't work, you can reset Maya to default by deleting your settings/preferences.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
