Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
UV Layout - some shells are in 45º
1 REPLY 1
Toquitaa
240 Views, 1 Reply
Hi folks!
I'm making a wall and I want to unwrap the bricks, but some of them are unfolded in 45º and some are 180º.
Is there any way to make the unfold process consistent?
I tried "Orient Shells" but it really doesn't work.
Thanks!
1 REPLY 1
hamsterHamster
in reply to: Toquitaa
Unfold is not limiting the result to any angles. You can use ArrangeAndLayout>OrientShells in the uvToolkit to straighten rotation, or rotate manually. However, for the 45° rotated shells you can select them all and click Transform>Rotate 45.000. Finally, when you do Modify>LayoitUVs, you can disable Rotation completely, or limit it to 45°/90° steps.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
