Announcements
Using paint tool to select objects?
Parmenides
Parmenides
I have always found it odd that you can use the paint tool to select verts, faces and edges but not the objects themselves. For example, if you have hundreds of objects and you want to select objects in a spiral pattern, your only choices are single picking each one or using the lasso tool.
Does anyone know of a script that would allow something like this?  Thanks.
Replies (0)
