Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
use 'cmds.xform()' to query position's problem
5 REPLIES 5
219 Views, 5 Replies
when I use 'cmds.xform(v,q=True,ws=True,t=True)' to query the vertexes' position, the return result are the same while the actual vertexes are not in the same position.
Labels (2)
5 REPLIES 5
in reply to: 1263870289
It has been bothering me for a long time,hope someone can help me solve this problem.
brentmc
Strange. It works here.
Try printing out "v" in the loop to see what gets passed to xform.
Brent McPherson
Principle Engineer
in reply to: brentmc
Yes, most of the vertices are fine, but these two vertices that I select are not working.The file is below and the vertexes'name are 'Geo.vtx[635]' and 'Geo.vtx[2321]'
brentmc
The vertices are at the same location but appear different because you have smooth mesh preview enabled.
Tap the "1" hotkey to get out of smooth mesh preview and you will  see the vertices are at the same location.
Note that you have a lot of triangles in the mesh and you really need to stick with quads for best results with subdiv meshes.
1) Mesh > Cleanup Options > Select matching polygons + 4-sided faces
2) Select > Inverse
Brent McPherson
Principle Engineer
Oh!It works!Many thanks for your help!
