Unfold3D process error
staceypeck
Message 1 of 76
staceypeck
I'm trying to unfold my UV map and I keep getting an error that says "// Error: Unfold3D process error." How can I resolve this?
Replies (75)
Message 41 of 76
Christoph_Schaedl
Its also fixed in Maya2020.2
https://linktr.ee/cg_oglu
Message 42 of 76
It's nice to hear.
Message 43 of 76
thanks bro!
Message 44 of 76
theantgroup3d
Community Visitor
Community Visitor
Ryzen 3990x the same issue. Looks like it needs adaptation
Message 45 of 76
thank you so much this works for me!!!!!!
Message 46 of 76
My plug ins are loaded in Maya 2019.  I am still having the error even after unchecking and checking again.  My model has had all history deleted by type and on one layer.  I created my own seams for unwrap but when I goto unfold it throws me the error.  This has never happened before.  I don't know about legacy but it works however I can not unfold the pieces and flatten them in any way that looks correct.
Message 47 of 76
This is NOT fixed in 2020.2
I had to download that fix on page 2 of this forum overwriting the unwrap files.
Autodesk, this is a lame that you would let such an important part of your program (unfolding uvs) be totally disabled / broken for RYZEN users.
There are many  many AMD Ryzen users out there.
Fix this problem.  It make your software engineers look embarrassingly incompetent.
Message 48 of 76
mspeer
Hi!
@Anonymous
Have you set set the environment variable MAYA_USE_ALTERNATE_UNFOLD_SHIM = 1 ?
This is required for Maya 2020.2 with a Ryzen 3900x series CPU.
Message 49 of 76
yup it also works with me Ryzen 7 3700x
Message 50 of 76
gimble
Keeping the plugin unchecked worked for me, with a Ryzen 3900
Message 51 of 76
There clearly seems to be a Ryzen compatibility issue here. I'm also using a Ryzen 3950x. Had no problems before using a old Xeon. Doubt this will be fixed anytime soon sadly.
Unchecking the plugin does nothing.
It seems to only work on very simple geometry.
Message 52 of 76
Christoph_Schaedl
It is fixed in the latest updates.
Message 53 of 76
Can confirm, issue still persists
Message 54 of 76
Christoph_Schaedl
Have you set the env variable?
Message 55 of 76
pedro_masa
Observer
Observer
there is a solution... you need to edit maya.env and add this line.
"MAYA_USE_ALTERNATE_UNFOLD_SHIM = 1"
Message 56 of 76
interactm
This seems to have worked!
Thanks for the reply.
Message 57 of 76
jamesEWHMV
Hi, I'm having the process error issue, using an AMD 5600X. Reloading the plugin doesn't do anything. OBJ exporting and re-importing the geometry also doesn't do anything. Using Maya 2019.3.1, all up to date.
Message 58 of 76
brentmc
Did you try editing maya.env and adding "MAYA_USE_ALTERNATE_UNFOLD_SHIM = 1" as described in the other replies and in this knowledge base article?
https://knowledge.autodesk.com/support/maya-lt/troubleshooting/caas/sfdcarticles/sfdcarticles/Unfold...
Brent
Brent McPherson
Principle Engineer
Message 59 of 76
jamesEWHMV
Followed the steps and it worked immediately. Thanks!
Message 60 of 76
Same for me
