Undo Error
martinmichl
Undo Error
martinmichl
Hello everyone,
I have a big issue with Maya 2017 and the undo command.
I detected it on several computers. After working on a scene for a while, the undo command sends me randomly an error message.
It has nothing to do with the undo queue, as you can see in the screenshot, it is still turned on.
The construction history is not turned off either and it writes this error message:
Thanks for your help in advance!
Greetings,
Martin
cornelh
@martinmichl
We have some other issues with the Undo command, but I have not seen this one yet.  Have you re-set your prefs. to see if that solves the issue?  Make sure you do not copy old prefs from 2016 or 2016.5 as this will create problems.  Please let me know if resetting your maya to defaults solves the undo issue?  If not, we will have to do some more in depth troubleshooting.
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
I look forward to your reply. thanks
