Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Unable to Unload Vray and arnold plugins from the scene.
5 REPLIES 5
imadil.khan
1346 Views, 5 Replies
I simply want to unload all the unwanted plug-ins from my scene. I am using Redshift for rendering and lighting of my scene but what i am seeing is that VRay and Arnold are also loaded in my scene which slows down the loading of the overall scene every time i open the file. So i went in the plug-in manager to unload Vray and Arnold. But it says-
1. For VRay:
Plug-in node(s) of type VRaySettingsNode exists in the scene.
2. For arnold:
Plug-in node(s) of type aiOptions, aiAOVDriver, aiAOVFilter exists in the scene
But i couldn't find any of these options there in my scene. So how can i remove these unwanted settings from my scene and use only Redshift settings instead. Also if you can explain where/how these VRay and Arnold nodes are being used.
PS: There is no Vray and Arnold materials/lights used in the scene.
5 REPLIES 5
What happens if you disable the View>dagObjectsOnly option? Can you find those now? If you can't seem to delete those, then you most likely need to unload the VRay and MtoA plugins and disable Auto-load, restart Maya.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
imadil.khan
in reply to: imadil.khan
Wow.. ! Never thought trying this way. Thanks alot. It worked.
I found the VraySettingNode and some arnold nodes. But it would be great if you can explain what was the purpose of those nodes?
I can see some more nodes in there so i would like to delete those if they are useless.
Thanks again..
Thanks again..
I am not too familiar with Arnold, and I don't know VRay at all. Let's think what can it be: engine specific shaders/utilities (Arnold: most of the nodes that begin with ai*), render settings, probably some renderengine-unique nodes. Usually you can get a hint by opening it's AttributeEditor
,,,_°(O__O)°_,,,
Thats Ok. I'll figure it out afterwards. Once again Thanks for the solution...
