I've been getting trying to get Maya 2022 to work in Linux (Ubuntu). I have followed the guide here: https://knowledge.autodesk.com/support/maya/learn-explore/caas/simplecontent/content/installing-maya...
All the dependencies are correct and I have the Autodesk licensing service working when testing with:
sudo systemctl status adsklicensing
I get:
adsklicensing.service - Autodesk Licensing Service
Loaded: loaded (/etc/systemd/system/adsklicensing.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-04-26 14:54:21 BST; 1h 51min ago
Main PID: 82006 (AdskLicensingSe)
Tasks: 16 (limit: 18846)
Memory: 10.2M
CGroup: /system.slice/adsklicensing.service
└─82006 /usr/bin/AdskLicensingService --run
Running the command
/opt/Autodesk/AdskLicensing/11.0.0.4854/helper/AdskLicensingInstHelper list
to check what is licensed I get:
"feature_id": "ARNOL",
"def_prod_key": "C0PL1",
"def_prod_ver": "2020.0.0.F",
"sel_prod_key": "C0PL1",
"sel_prod_ver": "2020.0.0.F",
"lic_method": 4,
"supported_lic_methods": [
2,
1,
4
"serial_number_sa": "xxx-xxxxxxxx",
"serial_number_nw": "xxx-xxxxxxxx",
"def_prod_code": "ARNOL",
"sel_prod_code": "ARNOL"
Following the guide this looks like Maya did not automatically register. So I tried the manual registration:
sudo /opt/Autodesk/AdskLicensing/11.0.0.4854/helper/AdskLicensingInstHelper register -pk 657L1 -pv 2020.0.0.F -el EN_US -cf /var/opt/Autodesk/Adlm/Maya2020/MayaConfig.pit
This didn't do anything, so I changed it to:
sudo /opt/Autodesk/AdskLicensing/11.0.0.4854/helper/AdskLicensingInstHelper register -pk 657L1 -pv 2022.0-218 -el EN_US -cf /var/opt/Autodesk/Adlm/Maya2022/MayaConfig.pit
However both gave me the error:
Error (13) for adlmPITSetProductInformation_2: PRODUCTS information is not found
I followed the rest of the instillation process and Maya now lists as a Application in Ubuntu. When I run it I get the message:
maya: Autodesk MAYA 2022
A licensing error occurred that Autodesk systems were not able to handle for you. Please contact Autodesk Customer Support for help in resolving this error.
adlsdkAuthorize returned with error code: ADLSDK_STATUS_LICENSE_CHECKOUT_ERROR
The default location for log files to help diagnose the issue is: /usr/tmp
I've spent a few hours trying to find a solution (and as ever this may be me Googling/searching the forum incorrectly) but I've not found anything that hint/helps this issue. I believe I am just not giving the licenser the correct application information, but can't find anything to hint/guide/tell me what to put.
For info, here is the output of /usr/tmp:
2021-04-26 16:05:18: ====== BEGIN MAYA CLM LICENSE DIAGNOSTICS (level 2) ======
2021-04-26 16:05:18: INFO: MAYA VERSION: Autodesk MAYA 2022
2021-04-26 16:05:18: INFO: Desktop Licensing Runtime Version: 5.0.1.40
2021-04-26 16:05:18: INFO: Desktop Licensing API version in Maya: 5.0.1.40
2021-04-26 16:05:18: INFO: initialize: GetInstance (Success)
2021-04-26 16:05:18: INFO: Received LicenseUpdateCallback for Maya 2022 (ADLSDK_UPDATE_REASON_LICENSE_UPDATE): NOT Authorized
2021-04-26 16:05:18: ERROR: Error Information: Maya 2022 : this product has not been registered with the licensing service yet
2021-04-26 16:05:18: ERROR: adlsdkAuthorize returned with error code: ADLSDK_STATUS_LICENSE_CHECKOUT_ERROR
2021-04-26 16:05:18: ERROR: checkinLicense: unable to release authentication handle
2021-04-26 16:05:18: INFO: shutdown: normal exit
2021-04-26 16:26:08: ====== BEGIN MAYA CLM LICENSE DIAGNOSTICS (level 2) ======
2021-04-26 16:26:08: INFO: MAYA VERSION: Autodesk MAYA 2022
2021-04-26 16:26:08: INFO: Desktop Licensing Runtime Version: 5.0.1.40
2021-04-26 16:26:08: INFO: Desktop Licensing API version in Maya: 5.0.1.40
2021-04-26 16:26:08: INFO: initialize: GetInstance (Success)
2021-04-26 16:26:08: INFO: Received LicenseUpdateCallback for Maya 2022 (ADLSDK_UPDATE_REASON_LICENSE_UPDATE): NOT Authorized
2021-04-26 16:26:08: ERROR: Error Information: Maya 2022 : this product has not been registered with the licensing service yet
2021-04-26 16:26:08: ERROR: adlsdkAuthorize returned with error code: ADLSDK_STATUS_LICENSE_CHECKOUT_ERROR
2021-04-26 16:26:08: ERROR: checkinLicense: unable to release authentication handle
2021-04-26 16:26:08: INFO: shutdown: normal exit
2021-04-26 16:36:55: ====== BEGIN MAYA CLM LICENSE DIAGNOSTICS (level 2) ======
2021-04-26 16:36:55: INFO: MAYA VERSION: Autodesk MAYA 2022
2021-04-26 16:36:55: INFO: Desktop Licensing Runtime Version: 5.0.1.40
2021-04-26 16:36:55: INFO: Desktop Licensing API version in Maya: 5.0.1.40
2021-04-26 16:36:55: INFO: initialize: GetInstance (Success)
2021-04-26 16:36:55: INFO: Received LicenseUpdateCallback for Maya 2022 (ADLSDK_UPDATE_REASON_LICENSE_UPDATE): NOT Authorized
2021-04-26 16:36:55: ERROR: Error Information: Maya 2022 : this product has not been registered with the licensing service yet
2021-04-26 16:36:55: ERROR: adlsdkAuthorize returned with error code: ADLSDK_STATUS_LICENSE_CHECKOUT_ERROR
2021-04-26 16:36:55: ERROR: checkinLicense: unable to release authentication handle
2021-04-26 16:36:55: INFO: shutdown: normal exit
2021-04-26 16:54:03: ====== BEGIN MAYA CLM LICENSE DIAGNOSTICS (level 2) ======
2021-04-26 16:54:03: INFO: MAYA VERSION: Autodesk MAYA 2022
2021-04-26 16:54:03: INFO: Desktop Licensing Runtime Version: 5.0.1.40
2021-04-26 16:54:03: INFO: Desktop Licensing API version in Maya: 5.0.1.40
2021-04-26 16:54:03: INFO: initialize: GetInstance (Success)
2021-04-26 16:54:03: INFO: Received LicenseUpdateCallback for Maya 2022 (ADLSDK_UPDATE_REASON_LICENSE_UPDATE): NOT Authorized
2021-04-26 16:54:03: ERROR: Error Information: Maya 2022 : this product has not been registered with the licensing service yet
2021-04-26 16:54:03: ERROR: adlsdkAuthorize returned with error code: ADLSDK_STATUS_LICENSE_CHECKOUT_ERROR
2021-04-26 16:54:03: ERROR: checkinLicense: unable to release authentication handle
2021-04-26 16:54:03: INFO: shutdown: normal exit
Thanks.
