unable to open maya after installation in linux
sanchitlogger
sanchitlogger
/usr/autodesk/maya2023/bin/maya.bin: error while loading shared libraries: libpng15.so.15: cannot open shared object file: No such file or directory
It is not working for me
similar case : https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-whi...
tkaap2
Do you have libpng installed?  Maya will look in /usr/lib64 for it.  So if /usr/lib64/libpng15.so.15 isn't there, install libpng.
Using yum, it's something like "sudo yum install libpng" .
If you ever see that a library can't be found, you can ask 'yum' if it knows of a package that provides that library file:
`sudo yum provides libpng15.so.15`
sanchitlogger
Thankyou for helping me. It worked, what i did is copied libpng 15.so.15 in /usr/lib64 folder.
