Unable to load MayaUSD plugin Maya 2027.1
manushkoshy2YHU87
New Member New Member
Message 1 of 1
manushkoshy2YHU87
New Member
New Member
I'm trying toload the MayaUSD plugin into Maya. I'm using version 2027.1. I've dowloaded both, version 36.0 and 35.0 from Github and installed it. It defaults to installing in C and I've left it there, my Maya installation is in Drive D. When i try to load the plugin from inside Maya, I get this error:
// Warning: file: D:/Maya/Maya 2027/Maya2027/scripts/others/pluginWin.mel line 937: Could not load C:/Program Files/Autodesk/MayaUSD/Maya2027/0.35.0_202602171127-017700d/mayausd/MayaUSD/plugin/adsk/plugin/mayaUsdPlugin.mll as a plug-in
I really need to fix this, does anyone know what the issue here is?
I've checked my PATHs, and there's no Nuke, and I don't use NVIDIA onmiverse.
Adding this here, because some other solutions seemed to be solved by removing the above from the paths
Thanks!!
Replies (0)
