Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Unable to edit and render XGen collection after updating Maya
6 REPLIES 6
Fritziundso
1219 Views, 6 Replies
Hey! I'm paniking. Our package at university just got updated, and i'm not able to access my XGen Collection anymore. It also doesn't render.
When i click on the Collection in the Outliner nothing happens, and when i click on the 'Open XGen Window'-Button it just allows me to create a new collection etc, but doesn't open the already existing one.
Any help? Please, i'm dying here. I put so much work in the fur-setup. ._.
6 REPLIES 6
sean.heasley
in reply to: Fritziundso
Hi @Fritziundso and welcome to the community! First off you can try deleting your settings/preferences and then double check to make sure you set your project to the right directory. If those don't fix it check this thread for info! Let me know if any of this helps you out 🙂
Michael_Todd
in reply to: sean.heasley
If you open an XGen scene and the xgen UI is not populated, just resave the file, open a new file to clear everything out and then open your XGen scene again. The XGen UI should repopulate..
Cheers
Michael Todd
XGen Product Owner and Designer
Fritziundso
in reply to: Michael_Todd
Thanks Sean for welcoming me, and thanks Michael for the solution^^' Who would know that a simple save would be the key :D.
This helped me a lot. Thanks al lot! 🙂
vegaplanet
Hi Michael,
I have the same issue but I don’t really understand what you mean. Should I resave my XGen file and open „New Scene“ and then open my XGen file again?
It’s urgent..
Thanks.
addisu_max
in reply to: vegaplanet
xgen is buggy. It's not only when you update Maya that happens but also when you imported a mesh from Zbrush or any other program. If not properly named that can happen too. The file path matters, you have to make sure to avoid a space while naming a file. Open the script editor and read what caused the error for more.
addisu_max
you can try exporting the collection and description then import it back in your newer version. you can also 'export all' (ascii format) too. FBX didn't work for me
