Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Turn on "Soft Selection" make edges gray out
7 REPLIES 7
Message 1 of 8
hai.tdh
193 Views, 7 Replies
Hi guys
I believed i accident turn on somethings.....
assually edges should be "cyan"
Please take a look at the image
7 REPLIES 7
Message 2 of 8
brentmc
in reply to: hai.tdh
Check the Show menu in the 3D view to see if Selection Highlighting is on?
Brent McPherson
Principle Engineer
Message 3 of 8
hai.tdh
Yes it is
Message 4 of 8
brentmc
Strange. Have you tried resetting your Maya preferences?
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Maya-Cus...
Brent McPherson
Principle Engineer
Message 5 of 8
cavescholar
Just a few thoughts, maybe try just resetting the Soft Modification Tool back to default.
Soft Select optionsSoft Select options
Modify> Transformation Tools > Soft Modification Tool Option Box.
From the  SOFT MODIFICATION OPTIONS window,  go to EDIT from top menu, RESET SETTINGS.
There are other settings you can mess with in this window also.
Alternately, maybe try to find the color and change to something else more noticeable through color settings.
Color SettingsColor Settings
Last suggestion is maybe turn on Wireframe on Shaded (alt +5 or Option key and 5 on Mac)
Wireframe on ShadedWireframe on Shaded
Good luck!
Message 6 of 8
amaterasu-qbb
I have the same issue, no matter using soft selection.
But I solve this by, restarting Maya, and typing 1 2 3 3 2 1 to smooth the mesh and not.
I hope it works for you too. @hai.tdh
Message 7 of 8
brentmc
We have been unable to reproduce this issue so wondering if it could be graphics card related?
You might want to check whether you are using the certified driver for your version of Maya or try switching your viewport renderer to DirectX 11 under Preferences > Display?
https://knowledge.autodesk.com/support/maya/learn-explore/caas/simplecontent/content/maya-certified-...
Brent McPherson
Principle Engineer
Message 8 of 8
hai.tdh
Actually, i got this issues many times but i not searching it until now (and i still got it because i'm lazy to del pref and do all my own settings again)
but i believed it appeared during soft selection modeling ( same with my own PC and company PC)
