Trouble with front view
veena_arun
veena_arun
I am fairly new to maya and am having trouble with the front view.  When I press spacebar>maya>front, it shows me the bottom view. Same thing happens when I try panels>orthographic>front.  All the other views work fine. I have never had this issue before and it's acting up only with the front view.
I have tried resetting preferences to default in the preferences window and renaming the prefs folder to prefsOld.    Neither solution worked.
Any other suggestions?
Christoph_Schaedl
How do you know its the bottom view?
If you create a cone is the pointy end on top`?
https://linktr.ee/cg_oglu
veena_arun
The view cube shows that it is the bottom view and also I see the bottom of my model.
artfully3d
You could try adding a new orthographic set to top view
