the model becomes transparent during animation
s19408
s19408
Hello!
Faced with this problem: the model becomes transparent when I click on play animation.
Checked the "transparency" - there are no keys.
When I click on the model, transparency disappears, I press play - transparency appears again...
Please help me to solve this problem
Parmenides
Hello, what testing have you done,
- have you replaced with a Lambert to see if the issue is material related?
- Also have you selected the mesh and gone to Mesh/Cleanup?
- Does it render okay? Or just a playback issue?
s19408
I tried replacing Lambert with Standard Surface/Ai Standard Surface, unfortunately, that didn't help, and neither did Mesh/Cleanup
The problem is the playblast, no such problem with the render, but I need the playblast specifically (
I have noticed that this happens after adding light to the scene. Could you please tell me if it is possible to fix it?
s19408
Thank you for the reply, but it doesn't work (
Parmenides
The only other thing I know of that would affect the transparency is Hardware Renderer settings. In your viewer window go to the Renderer menu/Viewport 2.0 setting and try all the different options for Transparency Algorithm. If those setting don't work you may have to reset your prefs.
s19408
I checked Transparent Shadows and it worked!
Thank you so much!
