Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
The IKhandle can not be created on the new updated Maya 2023.1
4 REPLIES 4
Easytalk2022
317 Views, 4 Replies
4 REPLIES 4
MaYa_people
in reply to: Easytalk2022
I got the same error, it's really too bad that this problem occurs
MaYa_people
in reply to: MaYa_people
The reason for the error should be that the ik tool cannot correctly identify the content in the vp window. However, you can click on the bones in the outline list to create ik control handles, which can be temporarily solved until autodesk does not give a complete solution.
brentmc
Thanks. We have reproduced this and opened an issue to track this.
Brent McPherson
Principle Engineer
kelly_hynes
The following defect has been logged and is being investigated by the dev team:
MAYA-124028 Cannot create IK handle via Viewport
Meantime, there are a few workarounds to the issue:
1.  You can disable 'pivots' from the Viewport < Show menu.
or
2. Select the joints in the Outliner by selecting the first joint then cmd/cntrl the second joint
or
3. Select two joints and setup as a shelf button and run:
string $getSel[] = `ls -sl`;
ikHandle -sj $getSel[0] -ee $getSel[1];
Hope this helps.
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
