Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
The hair made of xgen goes inside the mesh.
5 REPLIES 5
4151 Views, 5 Replies
How can I fix them? ...I was put '1' in region mask and draw region mask but can not fixssssssssssssss.jpg
5 REPLIES 5
sean.heasley
Hi @Anonymous
Do you have collisions enabled to the hair can collide with the mesh?
Also what happens if you readjust the guides to be outside the mesh?
sean.heasley
in reply to: sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
The problem was solved when clearing the clumping applied to the hair.
sean.heasley
Hi @Anonymous
Awesome! Thanks for explaining what you did to solve this I went ahead and marked it as the solution for this thread.
himinglaeva47
This was happening to me. For whoever has this problem you either create a part or another description for wherever the hair parts or guides head the opposite direction.
