Announcements
The Framework 4.8 library in Maya 2026 fails to load unless .NET Core 8.0 is installed
Itsautodesklicense3
Itsautodesklicense3
Hi Autodesk Team,
I'm trying to load my C# .NET Framework plugin into Maya 2026, but the application seems to require .NET Core 8.0 instead. We're unsure why it's expecting .NET Core 8.0 for a plugin built with the .NET Framework.
Steps I attempted:
  • Created a Class Library project targeting .NET Framework 4.8
  • Added a reference to OpenMayaCS.dll to access the IExtensionPlugin interface
  • Implemented the methods in the plugin:(file attached for reference)
  • Built the project to generate the plugin assembly
  • The following files were placed in the C:\Program Files\Autodesk\Maya2026\bin\plug-ins directory:
    • mayasampleplugin.dll
    • OpenMayaCS.dll
    • OpenMayaCS.runtimeconfig.json
  • Launched the Maya 2026 application. Navigated to
  • Windows → Settings/Preferences → Plug-in Manager.
  • The mayasampleplugin appears in the list, but it fails to load.
  • After installing .NET Core 8.0, the plugin successfully loads in Maya 2026.
  • The DLLs mentioned above have been attached.
Itsautodesklicense3
nelsoncruz
If I am understanding everything correctly, sounds like this would be expected as Maya 2026 moved to .NET 8.
Help | Maya is moving to .NET 8 | Autodesk
Nelson Cruz
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Itsautodesklicense3
Before we dropped our .NET Framework plugin, it was working with Maya 2026. However, when attempting to load our plugin now, Maya expects .NET Core 8.0. Which part of the plugin loading process is triggering this requirement for .NET Core 8.0?
