Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Texture to Geometry issues
1 REPLY 1
arcon76
45 Views, 1 Reply
Convert texture to geometry seems broken in 2022.4. It works sometimes, and with other images just does nothing, tessellates the plane into two triangles but nothing based on the image, no error given.
The fact that it takes 5+ minutes each time on a high-end CPU and is this buggy is a bit of a joke in 2023...
I tried 2024 same problem.
File attached to reproduce the error with the texture included. Note that the same method produced the shapes you see in the file so its not my method that's the issue, for some reason some images just don't work which is not helpful.
Tags (1)
Labels (1)
1 REPLY 1
arcon76
in reply to: arcon76
So my solution to this was not to use that feature lol. Uploading all my textures to vectorizor.io gave me SVG files which I could easily create geometry with.
