Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
SynColor error? Maya Arnold render issues
3 REPLIES 3
azuazuazuki
1640 Views, 3 Replies
Hi, I'm getting below error with Maya 2020 and rendering result by Arnold is darker than it should be.
I have Maya 2018 and 2019 installed as well and they work fine...
# Error: line 1: UnicodeEncodeError: file C:\Program Files\Autodesk\Maya2020\bin\python27.zip\encodings\utf_8.py line 16: ascii #
# Error: line 1: [SynColor 2018.0.80]: XML parsing error (not well-formed (invalid token)) at line 5: synColorConfig.xml
# Error: line 1: [SynColor 2018.0.80]: The SynColor transforms are not installed: C:\ProgramData\Autodesk\Synergy\SynColor\2018\transforms
3 REPLIES 3
Stephen.Blair
in reply to: azuazuazuki
Check the paths in  2020/prefs/synColorConfig.xml
For example, accented characters can cause that error:
https://forums.autodesk.com/t5/maya-shading-lighting-and/arnold-renderer-fatal-error-attempting-to-s...
// Stephen Blair
// Arnold Renderer Support
azuazuazuki
in reply to: Stephen.Blair
Hi @Stephen.Blair , getting there, will try thanks
Stephen.Blair
You can use your favorite text editor to view and edit the xml file contents.
If you're not sure about it, post the content here...
// Stephen Blair
