Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
SVG Scaling issues
0 REPLIES 0
Message 1 of 1
mozorkvohra
64 Views, 0 Replies
SVG Scaling issues
Hopefully someone can help here, but I cannot seem to get an SVG from Illustrator into Maya at the correct units. No matter what format or size I create in Illustrator, once I import it into Maya there's seemingly no correlation between the apps. Currently, If I import a 2cm X 2cm square into Maya, then I need to change the display grid to Gridlines every 1 unit with 86 subdivisions https://19216801.onl/ https://routerlogin.uno/ .
If I import each shape separately, then they seem to import and take up the same size regardless of the size they are as an SVG. What the heck am I not doing right here?
Any help, someone please...?
0 REPLIES 0
