Source file not found
Autodesk Maya 2015
Source file not found: C:\Autodesk\WI\Autodesk Maya 2015\x64\Maya\Autodesk\Maya2015\Common Files (64-bit) Folder\Autodesk Shared\AdLM\R9\ja-JP\Webdepot\NSA_RTSaveLicense.html. Verify that the file exists and that you can access it.
Retry Cancel
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
In most cases, this issue is related to the anti-virus software on your machine. You will need to temporarily disable the anti-virus software before installing Maya. Check out the information in the links below for further reference:
Error: "Source file not found: 93437458-FD45-41D9-8F2E-8B4F60CF9356.dll"
Maya Not Installing Source File Not Found
Hope this information helps! Let us know how it goes. Thank you.
Jeffrey Sin
Autodesk Customer Support
Hi Jeffrey,
Thanks for the warm welcome to the community. Unfortunately no it did not work, am missing - NSA_RT Save License. html
Jeffrey Sin
