Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
sound not playing or showing up
12 REPLIES 12
Message 1 of 13
timaging
19731 Views, 12 Replies
see screenshot attached. I have my sound selected, it's set to play back real time, but no waveform in the timeline and no sound.
This was working fine yesterday
Dave
12 REPLIES 12
Message 2 of 13
sean.heasley
in reply to: timaging
Hi @timaging
Have you tried re importing the sound file?
If that doesn't work, could you try opening a new empty Maya scene and see if the sound file works there?
Let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 13
timaging
in reply to: sean.heasley
re-importing seems to work… in general I’m having issues with the mac version. Did you see my post on animating from Point A to B? That one is a killer for me because I need to duplicate this animations and they keep breaking.
Message 4 of 13
sean.heasley
Hi @timaging
Glad this worked for you! I haven't seen that thread but I'll go take a look at it!
Message 5 of 13
I tried many things Audio not playing with play controls only plays while scrubbing the timeline
I have this problem I imported .wav file audio for lip-sync animation. The audio is not playing with the play controls in Maya.
My settings are
frame rate = 24fps
playback speed = 24fps x 1
Maya 2020 student version.
Can you please help with this is for a college project.
Message 6 of 13
zilnav
I am having the exact same problem.  I have the proper playback speed.  I can scrub and hear the audio, but not when I click the play button.  It's manageable but really annoying.
Message 7 of 13
mrtobycook
I have the same problem, with trial version of Maya 2020. Audio doesn't play back when I click play - only plays when I scrub the timeline.
Message 8 of 13
Change the evaluation mode from DG to Parallel and should work.
Message 9 of 13
Thank you for this !! I was getting really frustrated and couldn't find the solution anywhere and this solved my audio problem !! Thank you!
Message 10 of 13
lizasmolinec
I have the same problem, however your solution doesn't help. Do you have any other options? I am working in Maya 2020
Message 11 of 13
reynaharris1
in reply to: lizasmolinec
try right clicking the timeline and going down to sound and make sure your sound is selected. and then in preference settings go to animation under settings and change the evaluation mode from DG to Parallel and see if that helps if you haven't already fixed the issue.
Message 12 of 13
I had the same problem. What worked for me was changing the playback speed. Make sure your playback speed is set to 24 fps, not every frame. You can find it under Preferences, Time Slider, Playback.
Message 13 of 13
1215624911
i found another question.        try right clicking the timeline and going down to Playback speed → real time
but today is2023 i think you've solved it
