Announcements
Snapping in Maya
Snapping in Maya
madrauchiha298
Snapping in Maya
madrauchiha298
Community Visitor
Community Visitor
Hi guys, I'm quite new to Maya (I decided to try switching from Cinema 4D after a long time). I feel like it's a great program with its own pros and cons. My question is: how can you easily snap an object or its pivot to the midpoint of an edge or polygon? In C4D, this can be done in just a few clicks, but I'm really stuck with this seemingly simple task in Maya https://100001.onl/
brentmc
Case 1: Snapping an object's Pivot:
1) Select your object, activate the Move tool and tap the D hotkey to edit the pivot
2) Hover over an vertex, edge or face and Shift + click to snap the pivot position to the component
Note: Without Shift the pivot will be positioned and aligned and you can also hold Ctrl to just align or Ctrl + Shift to Aim)
Case 2: Snapping  objects to points:
For snapping objects to points hold V and click the center of the manip and drag it over the point you want to snap to.
Note: X is the hotkey for snapping to a grid in Maya and works the same way
Case 3: Snapping  objects to center of an edge/face:
The easiest solution here is to load the Bonus Tools plugin (Window > Settings > Plug-in Manager > bonusTools) and then use Bonus Tools > Modify > Snap Align Object(s) to Component. (open the options for the most control)
1) To use it you first select an object
2) Right-click on the geometry you want to snap to choose edge or face mode
3) Shift-click on a single edge or face
4) Then use Snap Align Object(s) to Component
Hope this helps!
Brent McPherson
Principle Engineer
