Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Shortcut for accessing the input line menu ?
5 REPLIES 5
LifeArtist
1017 Views, 5 Replies
Good Evening,
I always use maya without status menu but sometimes I want to place my object at specific coordinates, therefore I need to reactivate the status menu and type in my coordinates.
Is there a way to not use it inside the status menu ?
5 REPLIES 5
pshwayka
in reply to: LifeArtist
You can use the move command in the MEL window. For example, to move an object to the absolute coordinates of 0,0,0 you would type:
move -a 0 0 0 <enter>
Not sure that's any faster though...
Smiley Wink
LifeArtist
in reply to: pshwayka
Okay so now I have just coded a small py script which will popup a window and you can put in the coordinates. <escape> Closes the window. <Enter> Moves the Object.
Maybe I will improve it. Have a nice day.
@pshwayka accepted yours because you gave me the hint. 😉
from PySide import QtCore as qc
from PySide import QtGui as qg
import maya.cmds as cmds
class SetPosition(qg.QDialog):
    def __init__(self):
        qg.QDialog.__init__(self)
        self.setWindowTitle("Set Position")
        self.setWindowFlags(qc.Qt.WindowStaysOnTopHint)
        self.setFixedWidth(250)
        self.setFixedHeight(40)
        self.keyPressEvent = self.KeyPress
        self.setLayout(qg.QGridLayout())
        self.cbox01 = qg.QComboBox()
        self.cbox01.addItem("Absolute")
        self.cbox01.addItem("Relative")
        self.layout().addWidget(self.cbox01, 1, 0)
        self.entry_x = qg.QLineEdit()
        self.layout().addWidget(self.entry_x, 1, 1)
        self.entry_y = qg.QLineEdit()
        self.layout().addWidget(self.entry_y, 1, 2)
        self.entry_z = qg.QLineEdit()
        self.layout().addWidget(self.entry_z, 1, 3)
        #self.labl02 = qg.QLabel("press <enter> or <escape>")
        #self.layout().addWidget(self.labl02, 2, 1, 2, 3)
    def KeyPress(self, event):
        if event.key() == qc.Qt.Key_Return:
            cmds.move(self.entry_x.text(),
                      self.entry_y.text(),
                      self.entry_z.text(),
                      absolute = True if self.cbox01.currentIndex() == 0 else False)
            self.close()
        elif event.key() == qc.Qt.Key_Escape:
            self.close()
dialog = SetPosition()
dialog.show()
pshwayka
I've marked your post as a solution, too. Glad you got it working.!
Smiley Wink
LifeArtist
I cant edit my post anymore but if someone wants to use this script:
add*
absolute = True if self.cbox01.currentIndex() == 0 else False,
relative = True if self.cbox01.currentIndex() == 1 else False) <---- This Line*
# Error: ModuleNotFoundError: file C:\Program Files\Autodesk\Maya2022\Python37\lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py line 142: No module named 'PySide' #
