Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Setting a hotkey for Key > Key Selected in attribute spreadsheet editor
3 REPLIES 3
josephpentland
138 Views, 3 Replies
Hello all,
Hoping someone knows a way to set a keyboard hotkey for the command Key > Key Selected in the Attribute Spreadsheet Editor?  I use this command constantly, but when I look at the script, it doesn't show any script for the actual command, only the result, which is the setting of the key(s) for all the individual components selected.  This makes the "custom hotkey" option unusable (at least I think).  Any thoughts would be much appreciated.
3 REPLIES 3
loncy888
in reply to: josephpentland
We cannot find the Attribute Spreadsheet Editor in the hotkey editor, perhaps because it is not currently supported.
If you are familiar with MEL, you can get the Command code from the Command Reporter after executing the menu command. Then use nameCommand to set the hotkey for it.
example: Attribute Spreadsheet Editor -> Name Menu
nameCommand -annotation "set nice name" -command "spreadSheetEditor -e -nn true SSEd" setSSEdNiceName;
nameCommand -annotation "set long name" -command "spreadSheetEditor -e -ln true -nn false SSEd" setSSEdLongName;
nameCommand -annotation "set short name" -command "spreadSheetEditor -e -ln false -nn false SSEd" setSSEdShortName;
hotkey -keyShortcut "F1" -ctrlModifier -name setSSEdNiceName;
hotkey -keyShortcut "F2" -ctrlModifier -name setSSEdLongName;
hotkey -keyShortcut "F3" -ctrlModifier -name setSSEdShortName;
savePrefs -hotkeys;
Thank you!
loncy
josephpentland
in reply to: loncy888
Thank you.  Exactly what I was looking for.  But now I'm having trouble finding what you call the "Command Reporter".  Any chance you could direct me to where it is?
Again, much appreciated.
loncy888
The script editor is divided into two panels. The upper panel is the Reporter, which is used to display command results. There you can see the commands the system executes after you click the menu, which are required to create the "nameCommand". You can enable "History" -> "Echo All" in the script editor to show more filtered information.
loncy
