Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Selecting with Move, Rotate, or Scale is laggy
1 REPLY 1
brittmaren9
96 Views, 1 Reply
Selecting or deselecting NURBS with the Move, Rotate or Scale tool has about a second of lagtime before its selected or deselected, but selecting with the normal select tool doesn't. My scene isn't laggy at all I have 3 referenced rigs with plenty of movement and it's a pretty annoying obscure problem I have https://192168ll.link/ https://19216801.onl/ . Has this happened to any of you guys? Any help or suggestions would be appreciated thanks
1 REPLY 1
matteo.dilena
in reply to: brittmaren9
Hi @brittmaren9,
are you using Maya 2023 by any chance? We had similar issues at work and it was because of a plugin called "drawUfe", so could be worth trying to unload it from the plugin manager window in that case.
That was fixed in 2024, so if you're using that version then it could be something else.
Hope this helps!
Matteo
