Selecting an entire edge loop in triangulated OBJ meshes from CAD
systembolaget
systembolaget
Selecting an entire edge loop by double clicking or selecting an edge on one side and shift selecting one on the other to select an entire edge loop does not seem to work with triangulated OBJ meshes from CAD.
Is there a way to do it instead of "woodpeckering" the Grow Selection Along Loop button for very long edge loops? Only with the entire edge loop selected, the UV shell can be straightened out with the Straighten Shell command.
hamsterHamster
Standard selection tools wont work on triangles. You might wish to Quadrangulate first - will work on your given example, not on more random edge distribution.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
systembolaget
Uh, no joy with triangle meshes from CAD then. Quadrangulating works only on extremely basic meshes. So "woodpeckering" is a bit tedious, but works ; )
Could one not write a MEL script that does the "woodpeckering" for the user?
hamsterHamster
Well, you probably can substitute woodpeckering in uvEditor with Select > ShortestEdgePathTool.
,,,_°(O__O)°_,,,
systembolaget
Thanks, that works.
