Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Select Edgeloop after bevel with mel
2 REPLIES 2
884 Views, 2 Replies
I'm trying to write a script that creates a cutline automatically
given an edgeloop
1 runs a bevel with 3 segments,
2 selects the middle edgeloop
3 runs a polymovefacet on the selection with a bit of Z offset to give the inset/bevel and creating the cutline
I know how to do 1 and 3 but I don't know if there is a way to select a specific/middle edgeloop after the initial bevel?
2 REPLIES 2
sean.heasley
Hi @Anonymous
You might find polyDuplicateEdge or polySplitRing useful.  Those are the nodes you get when you use the Offset Edge Loop or Insert Edge Loop tools.
Also, here's a little script that uses offset twice that may help you
polyDuplicateEdge -offset 0.5;
polyDuplicateEdge -offset 0.3;
string $edges[] = `polyListComponentConversion -fromEdge -toEdge`;
select `polyListComponentConversion -fromEdge -toFace`;
polyMoveFacet -localTranslateZ -0.05;
polyDelEdge -cleanVertices true $edges;
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
in reply to: sean.heasley
that's very helpful thank you, I found this piece of code to work perfectly:
from pymel.core import *
edges = ls(sl=True)
polyDuplicateEdge(edges, of=0.05)
faces = polyListComponentConversion(fe=True,tf=True)
polyExtrudeFacet(faces, keepFacesTogether=True, thickness=-0.5)
Technology Administrators
