Script or Setting to show NGONs?
adamzeliaszEBGV8
adamzeliaszEBGV8
Is there a MEL script or setting to show NGONs on my mesh? I would like to be able to highlight the faces. I use to have a MEL script that would show those, but I lost it.
Thanks!
zewt
I don't know a way to just highlight them in the viewport, only to select them.  One way you can do that is to use Mesh > Cleanup, set it to select polygons, and enable "Faces with more than 4 sides".
You can also use Select > Use Constraints, set it to "all and next", and set Order to "Nsided", then you can select all faces and it'll limit the selection to ngons.
