Script errors occur when using UDIM for mapping
misakimiku
misakimiku
I have no problem using maps normally, but as long as the UV tiling mode is set to udim or other modes, it will appear:
file: D:/Program Files/Autodesk/Maya2020/scripts/AETemplates/AEfileTemplate. mel line 665: invalid syntax #
This error, and then the map will not be displayed. I tried to install Maya to other drive letters, which is also the problem. I copied this script file from other computers and replaced it. It is useless. The problem remains the same
ericsonaguilar
Observer
Observer
I am getting the same problem! I've re-installed maya 2022 and still getting the same problem.
Stephen.Blair
Lines 664 and 665 are
	string $oldParent = `setParent -q`;
	setParent $parent;
so the problem seems UI related (parent in this case is like parent window/form).
Maybe try with a default workspace and layout?
// Stephen Blair
// Arnold Renderer Support
ericsonaguilar
Observer
Observer
Switched workspace from classic to general and  still getting the same error.
airelav_83
Observer
Observer
did you find a solution? I am getting the same problem!
